MF135 AD3.152 Throttle Linkage
DonJDavis
Hello, just putting everything back together after painting and I can't remember how the throttle linkages join together closer to the steering wheel side. Does anyone have a diagram that they can share? I have manuals but they don't show the connection configuration. I have the join piece but can't figure it out between the throttle are and the first linkage. It's a 1969 MF135, thanks.
Do you mean this?
Hi RedMF, that diagram looks similar but mine is a lot simpler at the throttle lever side, there definitely isn't as many washers and nuts (number 6), I'm on the road at the moment with work so will have a look at mine and compare to this diagram when I get back home on Thursday. Where did you get this diagram? I was looking on the web for something like this but couldn't find anything. Thanks, Don
You need to get a free login to the AGCO parts books from your nearest Massey/AGCO dealer. If you use search term '135', it will give you a variety of books to look at. There were quite a few books relating to the 135, I searched a couple of them for 'throttle' and the pics seemed the same so I concluded that there was a good chance yours would be too.
Perhaps you could have a look through the 135 books 'till you find the one which looks like your setup.
www.agcopartsbooks.com
Hello, ptfarmer, thanks for the link, this website is awesome for finding diagrams. I still can't seem to figure out how to get the bolt back in to the rear diff lock lever after I removed it for painting, even the diagram is a little vague, have you ever come across this? Thanks, Don
