John Deere PTO shaft removal on 4630 quad range
It been awhile since I removed one on a JD 4630 but I am pretty sure you can remove it from the back only on the Synco range and quad range. I have done a JD 4640 and that was from the back only.
Power shift models require a split. The power shift has a bolt in it from the front.
(quoted from post at 20:09:29 09/25/16) It been awhile since I removed one on a JD 4630 but I am pretty sure you can remove it from the back only on the Synco range and quad range. I have done a JD 4640 and that was from the back only.
i just finished changing the shaft and yes you can do it without splitting it so easy
