John Deere B rear wheel hubs B2188R
Ack
New User
Would like to know the difference between a B2188R bolt in hub and a B2096R. I have a set of cut off wheels that had A2994R hubs and need to figure out what B hubs I need to find so that I can use them. Thanks for the help
My book shows that the B2188 hub fits serial numbers B60000 and up.
B2096 hub fits B60000 thru B200999.
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]Would like to know the difference between a B2188R bolt in hub and a B2096R.[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the diagram below.
a238280.jpg" width="650"
Note the rear wheel hub (Key 4) [b:654c4848f0]B 2188 R[/b:654c4848f0] and rear spoke type wheel for rubber tires (Key 6).
Rear wheel hub [b:654c4848f0]B 2188 R[/b:654c4848f0] is designed for "factory flat spoke" wheels designed for mounting rubber tires.
a238282.jpg" width="650"
Note the hub (Key 4) [b:654c4848f0]B 2096 R[/b:654c4848f0] and flat tire steel wheel (Key 6).
Hub [b:654c4848f0]B 2096 R[/b:654c4848f0] is designed for "skeleton" steel wheels that do not have a rubber tire.
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]I have a set of cut off wheels that had A2994R hubs and need to figure out what B hubs I need to find so that I can use them.[/i:654c4848f0][/b:654c4848f0]</font>"
a238283.jpg" width="650"
Note the hub (Key 4) [b:654c4848f0]A 2994 R[/b:654c4848f0].
Hub [b:654c4848f0]A 2994 R[/b:654c4848f0] is designed for "skeleton" steel wheels that do not have a rubber tire.
Presuming that the only difference between the Model A wheel (50" x 6") and the Model B wheel (48" x 5-1/4") is the height and width, then the hub [b:654c4848f0]B 2096 R[/b:654c4848f0] for the Model B probably could be used.
Hope this helps.
