moleman_alma
New User
I am looking for any suggestions for help on a Belarus 400an, air cooled, diesel engine. Initial start up is great, idles and throttles correctly. While in use it will run for an hour to 2 hours and then just shuts down. wait about 20 minutes and it will start up roughly and then come to idle great and run again for the same amount of time and shut down again. I can run tractor stationary for a couple hours with no shut down, then if I hop on it and drive it through the field then it shuts down. I pulled the fuel filters and they seem fine(it has 2). Drained fuel tank and found very little debris. Oil changed, air filter checked/clean. (oil bath with sponge prefilter). changed oil in fuel pump. fuel lines seem solid, belt's good, mechanical fuel injected. its a 1995 I believe with less than 300 hours. I don't know where to look next to see why it shuts down. Any help would be appreciated. I am located in Liberty Center, IN if you may know of a local service center, as I know these tractors are not so popular. Thanks.
