I have 1991 GMC k1500 that I will use to go to tractor shows. I bought it in March and having been fixing all the little things. Several times when I have driven it to the store it won't start at the store. Nothing, no clicking from the starter solenoid, the battery voltage will read 12 volts with the switch turned to start. Also the snow plow motor will run and lift and the headlights will remain bright. I have cleaned the battery cables, replaced the broken ground wires to the frame and cab. If I jump it from another vehicle it starts right up. Turn it off and starts every time. I believe the wife is tired of coming to get me, her comment was, I don't know you take that thing, or something like that.
Thank you in advance, Bill
