BolivarRatman
New User
I have a 3 cyl gas, mid 70s JD 1020. Started running rough and died. Can't get any fire out of distributor. Have tried:
-new/rebuilt distributor
-3 dif caps & rotor buttons
-2 dif 12v coils & 2 sets standard points
-2 dif electronic ing modules & high energy coils
-new plugs & reworked plug wires
Basically its new from dist to plugs.....STILL....no spark out of distributor.
-has battery voltage on + side of coil, 0.6 on - side with points, bat voltage with electronic module
-have battery voltage on center button in cap from coil wire
-can get bat voltage to tip of rotor button
-rotor button position appears correct to service manual specs @ TDC. Does not appear to have jumped time.
-dist IS turning
No spark...
-cleaned bat ground @ block, distributor base and fork. Continuity meters good ground.
-previously running with a new bat, alt & ing/charging system has been completely rewired.
Basically have checked, metered, or replaced all I know to. I am now begging for any suggestion or input...
-dist IS turning
No spark...
