(quoted from post at 12:52:42 07/21/16) can i use a 1 ohm 10 watt resistor between coil and ignition on a to30 tractor for 12 volt conversion?
ell, thereyiu have it, tractor12………….one no answer, 3 partially correct answers. John's is closest & is on the safe side. Unless you have an unusual coil, what you propose will work, unless you leave ignition on with engine not running.(quoted from post at 12:52:42 07/21/16) can i use a 1 ohm 10 watt resistor between coil and ignition on a to30 tractor for 12 volt conversion?
