hydraulic jack repair?
55 50 Ron
Can a hydraulic jack be repaired? It is quite old and I don't see any place where it could be taken apart. It is 6 ton capacity and stopped working instantly like something broke. Worked good up to that point.
Been thinking of a new one with higher ton capacity even if old one is repairable.
I have an old (45 years) Hein Warner that suddenly quit several years ago. I took it apart and found a check valve (ball bearing and spring) with some rust on it and stuck open. A good cleaning and I was good to go. I would look harder at the pump mechanism. They tend to be very simple.
