1956 Ford tractor Series 600
RWAG
New User
This tractor has a loader, and both hydraulic rams need seals and O-rings. The ram housing is 29 1/2 inches long and about 2 1/2 inches in diameter; and the rod diameter is ~1 3/8 inches. There is a Ford tag, riveted to the left bucket arm with two numbers. The first is I9-335, and the other is Serial I-286. Does anyone know if these numbers refer to the hydraulic rams? If not, does anyone know what seal kit woiuld fit these rams? Thanks for your help.
Most any good Ford/New Holland/...../..../..., whoever they are now, can look up those numbers and get you parts and a
manual. Or as was said, just take the cylinders to a hydraulic repair shop and pick them up all fixed.
