Need a wheel. What else does it fit?
showcrop
I need a wheel to go on my Intl. 990 mower, as someone wants to buy it. It is six lug, on 6 inch circle, the pilot hole seems to be 4-3/4. It is the same as on my baler but I need that. It is probably a common implement size but there are no ag equipment salvage yards in the area. I am hoping that I can ask for one off from a particular truck, at an automotive salvage yard.
That rim is a common size that will fit on most tractors that are 6 lug or balers etc etc. I have NEVER found a car or trick rim tha twill fit. Many old balers used that on the heavy side but in a 15 inch and most tractor used that in a 16 inch. I keep 2 or 3 of those around as spares so when I get a flat and have hay down etc I can just change it out and go back to the field
Ag size rim, won't find on car. Common to wagons
implements, tractor front tires and skidsteers.
They sell for about 50$ each from Wold or CTD.
I think the pilot is 4 5/8" if I recall.
(quoted from post at 05:21:17 07/01/16) Probably a front rim off of one of your Ford
tractors will fit.
Yes I did look at the ones from my 960 that are under my 9000, and they do look the same. trouble is I can't spare one of them. My buddy has a pair that he is not using so I am going this AM to get one of those at least for temporarily.
There are thousands and thousands of used wheels that will fit it out there. So question is where are you at? Friend runs a junk yard and just cut up one of those units so do you need any more parts. This is in Ohio.
(quoted from post at 07:44:48 07/02/16) There are thousands and thousands of used wheels that will fit it out there. So question is where are you at? Friend runs a junk yard and just cut up one of those units so do you need any more parts. This is in Ohio.
It needs a shoe and a push-over tube. I did get a wheel, my buddy next door had one. My friend that is buying it is a very good welder so I expect he will whip up a shoe himself, but I will let him know about the one that your friend has.
