Don't know what to tell you about your skid steer, except my Farmall C and Jubilee doesn't like UTF in the winter. Farmall C pump sounds like it cavitating. Jubilee 3 pt won't work until it warms up, too thick. In big bold print, it says on my Terramite not to use transmission. Transmission fluid will damage the hydraulics. It says to use 10w40 motor oil in summer 10w30 winter. I even called the factory and they confirmed I should use motor oil not TF.
I just gave a friend an unopened 5 gallons of UTF. He was going to try it in the hyd of his 1963 Massey 35.
I would do more research and see exactly what it calls for.
geo.
Actually the Jubilee needs CHN134, thinner oil. It has 3 separate compartments, one tranny, hydraulic and third is the rear end. The older tractors tranny, rear end and hydraulic were all the same oil.
gene, Here is a post form the Ford N site. Same oil for tranny and rear end, hyd pump uses the same oil. geo.
8N
