Re: Bringing a Crabb Sawmill back to life and back to work!
Looks like a Detroit engine, can you raise the door and slide it out long ways? Is that the plan or you thinking of leaving it in the building?
Reminds me of my dad's old saw mill that he ran off JI case. He enjoyed making sawdust
in this later years, hobby only. Later he wired up a phase converter and powered the
mill off two 3 phase motors. He found it saved him on fuel and did a better job. When
under load, blade speed reduced, caused it to warp a little changing the cut.
If I recall, he had a 4 ft blade with removable carbide teeth.
Have fun. geo
What are you going to use to remove sawdust from the pit?
My Dad started with a shredding machine blower. Was not satisfactory for a couple reasons:
a) Our mill was underpowered, and the blower slowed when sawdust production was highest - heavy sawing.
b) Chips of bark would fall into the pit blocking the entrance pipe.
We went to a drag chain with paddles - ran slowly; but removed sawdust 100% of the time even when idling like putting a new log onto the carriage.
I've seen 3 or 4" augers run without a tube that do a good job.
I looked it up and a fellow brought one back to life on the forestry forum in 2007 it had a 4-71 for power with several pictures .
How big is the Crabbe. I grew up on a Corley, and some on a Foley I believe, 3 head block mills. I packed slabs and lumber at 15 yrs and 90 lbs, bout worked me under.
