Hydraulic Filter
RockRon
The 3-point arms quit lifting on my tractor two weeks ago. After several hours of troubleshooting in my "spare time", I believe I finally discovered that the problem is simply a bad hydraulic filter. Once I removed the filter everything began to work again. Seems simple enough, except I cannot find a replacement filter. This is for a Deutz D4006. The filter I have is made by Argo and is part number P3.0607-72. For anyone that is familiar with Deutz, this is the smaller filter they used before they added an extension kit and went to a longer filter.
Any sources would be greatly appreciated!
Ron
I copied and pasted that number into Google and a source came up immediately. Now it's up to you if you want to pay that price or not.
Have you ever heard the expression "Google is my friend"? Well, I googled your filter part number and it wasn't very friendly. I googled your tractor model and came up with this.
Good Luck.
Mark
Maybe this?
I don't know what operating system you use, but I can just highlight that number and right click, and google search is an option. That took me right to the filter, $47, that's not to bad if you only change it occasionally.
Sorry, Google wasn't my friend because I didn't use Google, I used Ask instead and it was Ask that wasn't my friend. After reading the other posts, I tried Google and it was my friend. As mentioned, $47.00.
Mark
