GeneMO
- Location
- Pilot Grove, Mo.
I have a leak in the oil cooler in this little Cat. I got to thinking about maybe plumbing it out of the system. Just put a hose between the outlet and inlet where it goes into the oil filter housing. Make a loop and run the oil right back in. Then plug the fittings on the oil cooler.
I rarely run this machine for more than two or three hours, and then dont run it hard. An engine that small doesn't seem like it would need to have the oil cooled.
If this is not an acceptable idea, wonder how I could test for a leak? I know it is leaking, just where is the question, and could I repair it on the machine.
I think some models had the oil cooler so it could be removed, but I dont think I can get the oil cooler out without taking the whole radiator off.
Thanks, Gene
Thanks, Gene
