Got my WD started finally.
Will Herring
Well, mystery solved all (link to old topic below). Took my 12V battery in to the local battery store (yes, we have an actual battery specialist nearby!) and he threw it on the load tester and the battery was bad.
So I got a pretty decent replacement from him, a heavy duty class 24 and went on my merry way. Made sure to clean the crap out of the battery cable contacts before I put the new one in, including where the wires attach to the starter saddle piece.
She fired up within 3 seconds of pulling the starter tonight after not having been run for 6 months. Got the plow hooked on and moved (though took probably 10 minutes, so much for "quick hitch", haha). Motor purrs like a kitten!
Link to old topic:
http://forums.yesterdaystractors.com/viewtopic.php?t=1271301
I finally took the battery to my forklift in to get it checked. It was only 7 years old and measured a charge of 12.7 volts, but it would not crank the motor even after a very thorough connection cleaning. At my locally owned independent auto parts store they put it on the tester and it showed almost no output. I got a new one for $100.00, put it on and it spins right over now.
HEY..an easy fix is to stop into HF and buy a load tester. They are cheep and work just dandy. Not a professional unit but for shop work they are just the thing. I have two and use them anytime I suspect a problem.
