Dan S (NY)
I picked up this Worthington F5 over the weekend. Not running, but the engine isn't stuck. It would have had 5 (or optional 7) gang mowers mounted to it when in use. Mowers are gone but I got the brackets for them. I need to put a battery tray and air cleaner back in it and rewire everything. This has the 134ci Ford NAA or 600 engine so engine parts aren't a problem. The clutch works, steering is actually pretty tight and the transmission seems to shift good. Production serial numbers run from 575 through 639 so they didn't make very many of these and I found this one only 10 miles from my house. Hopefully I can get it running for our local show in July.
Dan
