2110 Ford Hydraulic system
paul0208
New User
How much pressure should I be pulling from my Ford 2110 Hydraulic System. My 3 point Hitch will not go up and down ???
First of all, always mention whether you
have the 1965-75 2110 that was built by Ford
or the 1980s 2110 built by Shibura.
They are completely different tractors.
Secondly if you are thinking you should have
down pressure on your 3 point that is not
the way they work. Except for an an
aftermarket Gannon kit that would add down
pressure Ford Never had down pressure on the
3 point. Ever.
If your lift arms are not lowering at all
that is another issue - probably the
unloader valve in the lift cover under the
seat.
If that is your problem I would ask on the
Ford Forum at the link below.
Just a heads up, if you don't have a repair
manual for your tractor that is the first
thing they will tell you that you need to
do.
Ford Forum
Thank You .. I have the Ford 2110 9D # C238597, This is the Tractor # , I unfortunately do not know the year. I purchased this a year ago , the 3 point hitch worked great . Now it stopped working. I do know it does not have down pressure.
I have a 1910, Check and make sure the hyd link is hooked all the way in. It might look locked but is not. Happen to min once spend a day working on it.
