LEAKING CLUTCH CUTOUT SOLENOID ON CASE 480C
I have a leak coming from the area of my clutch cutout solenoid on my Case 480C. Has anyone ever addressed this issue? As far as I know, the solenoid assembly screws onto the end of the control valve. The control valve assembly is installed from the other side of the housing so I'm guessing that any seals or O-rings would be on the end of the control valve. It appears as if the control valve may be longer than the space between the frame and the transmission. Hopefully, the trans doesn't need to be dropped in order to address this.
All help is welcome.
Thanks
As I recall, there is a lip seal on the spring loaded plunger you see after you unscrew solenoid. can't remember if seal can be changed at this point, or valve has to be disassembled.
