Northvale - PA
so I replaced the load control shaft bushings and seals in my 4020 power shift last weekend. They were leaking pretty bad. When I got the old seals out, I found someone
had silicone sealed them in. The races both looked scarred too. I assume this was not a factory thing but a home fix. So, I set the new ones both in with sealant as well.
The bushings I set in with grease. Make sense? Tractor has about 6500 hours on it, says the tact. How much time can I expect on the new bushings and seals? I might plow a
4 acre hay field every 2 years or so (3 bottom). Snow blower in the winter. Otherwise, I don't use the 3 point hitch much.
