WD45 Headlight switch
GregoryKS
I'm replacing the headlight switch on WD45 with 12 Volt, Alternator system. May I replace the switch with the stock one most vendors offer used with generator?
Would not be necessary. Just use a 2 terminal off-on switch with fuse. The more expensive OEM switch has a resistor for the charging system which is not needed with the alternator.
