1486 hydraulic problems
Br549mech
New User
I am working on a 1486 with a gear type hydraulic pump and the remote hydraulics will only raise the plows at wide open throttle. The pump and filter are both new. I took the top link bracket off so I could look for internal leaks there is a stream of oil comming from the right rear corner from the unloading valve area. The flow of oil increases when trying to use the remotes.
