Married2Allis
Just wondering how low the temps can get and your diesel tractor will still start without using ether or an engine block heater? 40's/30's/20's/10's, lower?
(quoted from post at 11:28:43 03/20/16) John Deere R, have started at -15.
(quoted from post at 20:19:16 03/19/16) Yes we know .. Keep spraying ether and wonder why it's hard to start
Agreed. Theres not a diesel on my farm that would start at -30F. Or a gas engine either. Not that I would ever try it unless it was a matter of life and death. Generally if the temp is below freezing I will plug in the block heater for a while. Started the MF Super 90 Perkins diesel today at about 25 with no pre heating. With just a single 12 volt battery it had barely enough cranking power but did start. This one will run smooth and smoke free even on a cold start. Both my newer Cases will smoke and run rough when cold but not this old Perkins.(quoted from post at 18:50:58 03/19/16) are you meaning -30F? That's something I'd like to see. You must have special fuel. The best starters I have had without any assist was my 510 MF or my 1570 Case which would start in the low to mid 20's above F.
