O.T. 1994 Dodge Ram 1500 brakes
IA Roy
Still working on them. Bled them again. When I took it out for a road test, I noticed I have no brake lights. I can't think of any possible connection to brake malfunction. The first thing I am going to check now is the brake switch under the dash. Strange thing is that the turn signals work fine.
Google brake switch malfunction on 94 Dodge Ram,I think there is a valve in the line that needs to be bled to center the sensor to make the switch function properly.Hope that makes sense,seems like I went through that years ago when I owned one. Hope that helps.
if I remember right the brake light switch in under the dash near the column. It fits into a stamped steel bracket and can move out of adjustment relatively easily. Bill
Brake light failure! Answer too obvious, blown fuse! No I didn't think about that until I took off the lower dash panel and switch off of the mounting bracket. Why did fuse blow? I will see if it blows again and then investigate at that time. Time to put it back together before supper.
Thanks for replies!
