Used JD parts
Where do you guys go for used parts for JD 820? I might need to search out the carburator bowl as the pilot jet idle part looks damaged and Im not sure if it can be fixed, need to take a close look at it. It will need a new pilot jet but I can get a new one of those sent over from the US.
Bill
Try Renaissance Tractor in Chehalis, Washington- (360) 748-0026. I'm assuming you're talking about the 2 cylinder 820, not the much smaller 3 cylinder model. He also is one of the few set up to do injector and injector pump work on 2 cylinder diesels.
Missed this on the first reading, but also assuming the carburetor parts are for the pony motor, as I don't think they made an 820 gas 2 cylinder.
You could try Grosz Wrecking in Garrison ND. 763-478-1556
The last time I was there (maybe 3 years ago) they had quite a few 1960s tractors.
I was looking for IH560 parts and did not inquire about Deerly de Parted JD units.
It is wheat country so many Wheatland/Western tractors and would suspect that they parted out some 820/830 units.
Just called him and he has maybe 8 pony motors on the ground. He will look to see if he has started to part one out and if it has the carb. You can give him a call in a day or so, after he has a chance to look.
