Kubota 6060 or 5660
Looking at buying a new Kubota tractor what is the difference in the 5660 and the 6060 besides a little hp and price? Dealer said something about the transmission just wondering if one was better than the other,haven't had a chance to look at them yet just called the dealer to get a price and see what they have available in a fifty hp range,thanks for any advice
(quoted from post at 08:05:59 02/07/16) Looking at buying a new Kubota tractor what is the difference in the 5660 and the 6060 besides a little hp and price? Dealer said something about the transmission just wondering if one was better than the other,haven't had a chance to look at them yet just called the dealer to get a price and see what they have available in a fifty hp range,thanks for any advice
I'd go over to Tractorbynet.com, they have a very active Kubota board there.
I assume you are speaking of the M6060 vis a vis the M5660SUH or SUHD. If you are speaking of the L6060, this is Kubota's largest CUT and is totally different from either of the proviously mentioned small utility models.
The M6060SUH is a lower cost version without some of the features of the M6060 and larger series models. Be advised that previous versions of the so-called Special Utility (SU) models were equipped with 4X2 gear transmissions that were synchronixed in 3rd and 4th only and without extendable lift arms, though current models have fully synchronized 4X2 transmissions, hydraulic shuttle, and extendable lift arms. Be certain that your dealer is not pricing out an earlier model that may still bew available.
Differences are well covered on the Kubota web site.
Dean
I would go with the M6060 . The tractor weight is about 1000 lbs. more than the 5660. Also if you get it with 4x wheel drive the M6060 has differential lock both front/ back. The 5660 does not. You also gain more HP.
