1995 873 bobcat
Darren1965
New User
Just wondering if anybody knows was psi rating of hydro hose would I need for the hoses going from hydrostatic to drive motors
Thx
ASSUMING you still have the original hoses, look closely at them... most hydraulic hose has it's PSI rating embossed or printed on it's outer jacket.
(quoted from post at 09:38:57 02/01/16) ASSUMING you still have the original hoses, look closely at them... most hydraulic hose has it's PSI rating embossed or printed on it's outer jacket.
Unfortunately they are in rough shape to see
Any numbers . Does any body know specs on this machine
Thx
I can't say for sure, but most hydraulic hose is going to be 2 or 4 wire. One way to figure it out is to take one line off and cut it with a die grinder. Count the number of wire layers, and that will tell you what you need.
That being said, I'd go with the 4 wire I if it was mine, just because.
Bobcat has parts diagrams on their website. Probably won't give you part specs but it will get you a part number to Google for more info/specs.
(quoted from post at 20:48:28 02/01/16) Bobcat has parts diagrams on their website. Probably won't give you part specs but it will get you a part number to Google for more info/specs.
Thanks for all the responses
A Bobcat tech finally got back to me
And said the relief on the hydro stats is set
At 5000psi
Thx
