Do you need them? are they advantageous or a burden to leaves and the tractors power output . We are just making baleage and currently have a j.d 1360 with flails but are considering trading it for a wide swath mower with no conditioner. With the hope being that we will save a trip around the field by not having to ted because of the wide swath mower and we can run the mower with smaller tractors that are better on fuel and hay will be better quality with more leaves. will we be sacrificing anything by having a mower with no conditioner in a baleage/wrapped hay operation,
there is also literature out there that says hay will dry faster initally to the 60% range if you do not damage the plant because the stem and leaves can respirate out the moisture better then if damaged, if i understand what the literature said correctly! your thoughts??
