Valve update.
DeltaRed
Yes,the valve was 'set' for closed center. As suggested,I simply cut off the long portion of the Power Beyond plug. Screwed it
back in and everything works as it should!Took less than 15 minutes. I just knew you guys would know the answer.Thanks guys!
Steve
(quoted from post at 21:31:02 01/11/16) Yes,the valve was 'set' for closed center. As suggested,I simply cut off the long portion of the Power Beyond plug. Screwed it
Steve
I'm glad you got it going but a true CC valve doesn't have a power beyond plug. When you got valve did power beyond plug have a plug in it or hose attached?
A 3/4" pipe plug is in the 'power beyond' plug/'valve'. # 36 in JD sellers picture.I just sawed it off at the end of the
threads.
