OT: 1998 Monte Carlo heater core change
eremoao
Got everything down to the heater core cover. Took out about 10 small screws and I can get the front of the cover loose, but the side towards the firewall won't budge. Can't see anymore screws but it won't budge. Anyone have any ideas on what I'm missing here?
The firewall side (IIRC) has the AC condensate drain to protruding from it and extending through the firewall.
It has a foam pad around it that MAY be stuck to the firewall.
Gently work the back of the tray a bit downwards as you pull the cover towards you/away from the firewall.
