A friend with Tractor problem
jbowen383
New User
Hi to all,
I have a friend that has an an older International Haverster and is furiously trying to get a snow blower attachment working before the snow hits us here in the U.P of Michigan. I do not have the specifics on the tractor as of yet but I told him it is possible someone on the internet could have the information he needs to make it work. He is having problems with the PTO hydraulics as he can lift the blower up in the air but it refuses to come back down. If there is anyone out there that may be able to help? Please let me know what information I would need to supply to help him remedy his troubles.
Thanks for your time in advance
John
2 tips- find out what model tractor it is, and also post this on the IH section of this board,
The first thing to check is the hose connections. One of the hose might not be snap in. Then more info of tractor and how he has it hooked up.
We have some very well versed IH guys on the farmall and IH board. If you post this question there someone will have an answer. First you will need to find out what model IH this tractor is to make it easier for them to help you.
We also would like to have some pictures of the tractor and snow thrower along with the other requested/needed information. You can not provide too much information! Armand
A cylinder with a bad internal leak will do that.It may be lifting by pushing out the rod.While it is lifted,see if there is pressure on the rod end,by loosening the line.
Thanks for your help. I reposted on the Farmall site with more information but still lacking pictures. I will remedy that ASAP.
(quoted from post at 16:31:27 11/27/15)
quote]
To this day I have found no faster way to bail water from a sinking boat than a scared man with a bucket. Dad. [/quote]
