Hot water heater busted.
On Monday woke up to no water pressure and lots of gushing sounds from the basement. 4 inches of water as the floor drain had plugged up from debris flowing to the drain. Got the water shut off and it all drained and dried out. Put the water heater in that night. Always something. But got it fixed for my land lord and she decided singer I took care of it to just call it even for Decembers rent.
That's probably cheap for her if she had to hire a plumber.
Still a nice relationship to have between landlord and tenant.
After sister had a pipi break and her water leaked for 3 weeks while she was in Florida, I made a water sensor that turns pump at the first sign of water on basement floor. A month later, I had a leak and very little water on floor, sensor worked.
We all know that it does not heat hot water but heats cold water and still we call it a hot water heater. Just one of those things we say that do not always make sense.
Sometime I need to do a better job proof reading my posts. Can't spell pipe and the water sensor is designed to turn the power off to the pump when it detects water of basement floor. Once the rain gutter needed cleaned, water got on basement floor after a rain. The water sensor did it's job by turning pump off letting us know there was water on the floor.
(quoted from post at 13:44:02 11/27/15) Sometime I need to do a better job proof reading my posts. Can't spell pipe and the water sensor is designed to turn the power off to the pump when it detects water of basement floor. Once the rain gutter needed cleaned, water got on basement floor after a rain. The water sensor did it's job by turning pump off letting us know there was water on the floor.
Yeah, that sounded pretty bad for a minute there. Woman having a pipi break that leaks for three weeks might be pretty serious.
