UncleTom
Have a Deere 2355 that a guy at work was using.Lost the steering and the loader hydraulics.Checked the oil and was a little low so we added a quart. Worked for 5 minutes. If we let it sit for a half hour it would work for another 5 minutes or so. Hauled it home and changed the oil filter on the bottom of the trans. I could see some very very small flakes in the filter. Took an oil sample from the filter into a white plastic cup and used a magnet on the outside of the cup and can pull small particles of metal from the oil.I am thinking that while the tractor sits for a while the metal that has plugged the filter settles out and we get flow for a little bit. We are going to get it fixed but could use your or others input on where the metal is coming from and what our next move should be. Thanks
