I want to make the hydraulics more usable on the tractor, the current pump is good for 6 GPM and 1100 PSI. I lucked out, it appears the existing pump uses a standard A flange mounting. Pumps are measured in cubic inches per revolution, I took the 6 GPM, then back calculated it to .97 cu in. I searched hydraulic pumps and found one with the same flange that is 1.95 cu in, which should give me about 12 GPM. The new pump is good for 2500 PSI, I do not know what the rest of the system will handle, so I will install an adjustable pressure relief valve and set it at 1200 PSI. It looks like the gear on the existing pump is integral with the shaft. I will cut the shaft off, bore out and broach the gear for a press fit on the new pump.
This looks pretty straight forward to me, at this point.
