Bosch Injector pump In Fiat 4 cyl
Dalex
My friend bought a ('70's ? ) Fiat Agri Power 7000. It is a 4 cyl diesel with a Bosch pump . It sat a long time , and two of the outlets don't put out any fuel , so he's going to pull the pump and get it rebuilt . The question is how do we locate the timing mark on this engine ? does it have a pin ? a mark on the flywheel or crank pully ? Something else ? Thanks for any replies....
I have the same tractor, send me an E-mail, I have some things to check before the pump is removed. Mine didn't run when I got it because of two stuck plungers. You may have the same problem..
E-mail should be open on classic, if not [email protected]
