The sale had some very good clean equipment. The weather was pretty good as there was a good breeze all day. Good major brand equipment brought good money. JD and CIH tractors did well. Anything else was soft regardless of the quality.
Everitt Tractor Sale Sept. 2,2015
TRACTORS
JD 2950 MFWD 5100 hrs. Good tires and neat looking tractor. $21,000
JD 3038E & 305 Ld. MFWD 385 hrs. Same as new $14,500
JD 3720 MFWD, cab, 405 LD,405 hrs. Clean $20,000
JD 4720 MFWD,400X ld, 1280 hrs, Clean $28,000
JD 4240 2wd Quad Range 9166 hrs. Real clean 2 owner $23,500
JD 4440 1982 model, 2wd,Duals,weights, 6721 hrs, $35,000
JD 4455 MFWD 5800 hrs. Same family owned since new
Duals, new rubber on tractor frt and rear, weights SHARP $62,500
JD 4555 MFWD, 7000 hrs., MFWD, duals, weights CLEAN $40,000
JD JD 7700 2wd, 3100 hrs, 16 sp PQ, 18.4x38 rears, Clean $31,500
JD 4440 79 mod,5800 hrs. 8 sp. PS, Duals $33,500
JD 4630 8300 hrs, QR, Super clean original paint, Duals $13,750
JD 2355 Cab, 2wd, 4200 hrs., clean $18,500
IH 1586 2wd, 5600 hrs. clean, good rubber $13,000
White 125 MFWD, 6727 hrs., Good and straight, paint just
weathered, Duals.( Deal of the day) $25,000
White 2-135 4600 hrs. Real clean, cab straight $11,000
CIH 140 MFWD, L760 LD, 3085 hrs. Same as new looking $65,000
NH TS110 MFWD, Bush Hog 5045 LD, Supper clean $39,500
IH 766 ran good farm honest tractor $4,950
JD 430 After market wide front, Rear wheels botched $3,100
Case yellow 1370, ran well Cab rough inside $3,400
White 2-155 4945 hrs. Cab clean, good rubber $8,500
White 2-135 6700 hrs., Run well, rough paint $4,200
AC 190 Diesel, Year round cab, good tires $1,500
Equipment
Vermeer 605M Round baler with mesh wrap, CLEAN!!! $13,000
JD HX20 rotary cutter, sharp $11,000
NH 488 haybine two years old cut 150 acres NEW $8,750
JD 237 26.5 ft. rock flex disk same as new $22,250
CIH 3950 26 ft. disk clean $14,500
McCormick 80 combine pretty good shape $1,200
JD 336 sq. baler with 30 thrower, clean $2,150
Hesston 4600 center line baler clean $3,000
(2) Brent 544 wagons clean $11,000 ea.
(2)Parker 2600 on parker 114 ton gears, clean $3,200 ea.
TRACTORS
Equipment
