Roger in Iowa
Will hot tanking remove rust from an over head valve engine head and from the valve lifter, tappet, or cam follower area of an engine?
Block and head is from a vertical two cylinder Jd. Water down the exhaust pipe. No carbon build up on either piston, but they are stuck, soaking in atf and acetone.
Have not removed the pan to access rust in lower end. The cam tappet area looks rusty by looking down. Drained 2 quarts of water followed by oil from pan.
Thanks for help or suggestions!
