Relocated my hydraulic filter, and boy what a difference.
Fatjay
My pump would scream when I raised and lowered the bucket, so I decided it was time to relocate the filter. Cracked it open in the process and cleaned the mesh out inside. Sadly didn't get a picture of that, but now that it's back together, it is silent and quick to lift the loader. Had no idea the ferguson had so much potential.
Pump started here:
Used temperature rated colapse free tubing, 1" ID.
Now it's up here, and everything works much better.
Very little engineering was involved with this machine, so little stuff I do makes it work much better.
A screen is considered a strainer, A filter you can not see through in simple terms but must be located on the return side not on the suction side.
It's a bit of a squirly setup. All the fittings are plumbing pipe, but they're not on the pressure side of things. It's a wagner loader built for the 8n/2n on a ferguson to-30. The original plans have no strainer or filter. The manual says to drain and strain every 100 hours.
