Geo-TH,In
I filled up my terramite with gas. One hour later I noticed gas running the fill cap running on the ground. I wiped off the tank only to discovered I put 2 gallons of gas in the wrong tank, put it in hydraulic oil tank. There goes 10 gallons of new hydraulic oil, 10w40. I also noticed 3 hydraulic cylinders leaking. Sure hope I don't have to rebuild all the cylinders.
The oil and gas tank look the same, on different sides of tractor. You can bet I'm going to color code the caps on each tank.
Plan to drain when oil cools off. Add new oil and flush it out. Only problem you can empty tank, but there will still be about 2 gallons in hoses, cylinders, pump and torque motor.
Got any ideas what I can do with 10 gallons of oil and 2 gallons gas besides using it to start a brush fire?
