paint it.
pretty much everything was painted at the factory - even the plug wires and radiator hoses believe it or not.
Here's a list of what was masked according to Guy Fay's originality guide:
battery ignition unit/magneto
secondary ignition wires
electrical terminals and terminal screws not assembled
serial plate and name plates such as generator, starter
gauge glass faces, lamp lenses
fuel strainer glass bowl
seat cushion
steering wheel grip
voltage regulator resistor
fuse holder knob
The tires/rims, batteries and muffler were installed after painting.
I used 2150 on my F 20 and it looks good. If you check out Fordson house they will be able to provide you with paint that is a darker red. The 2150 can look orange ish in the bright sun light.
I think Dupont 7410 and PPG 70019 are a match for this tractor.Have been looking at our hosts Farmall red how does this compare?Is the spray can comparable?
