Hydraulic connectors
Jd750
New User
I need some help identifying these connectors. I also need to know what I need to connect to these fittings
<image src="http://forums.yesterdaystractors.com/photos/mvphoto26405.jpg"/>
They are Pioneer Connectors, I can read it on the connector from my house. lol If they are mounted correctly, they are break-away connectors. Female, Pioneer Breakaway connectors. They may have another name, I'll wait for a more educated response. gobble
Can not tell for sure but looks like you need Pioneer or ISO ends.
The one on the right is an adapter to go from Pioneer to JD.
Pull it out and you will have two Pioneer.
Unless your hose ends are already JD then buy another adapter and go.
Gary
So if I get two jd connectors on my new hose and take the adapter out I should be good to go?
NO!
You need pioneer/iso tips on the hoses, then unplug the jd adapter out of the RH coupler body and you will be all set.
