Can you ID this sprayer Nozzle?
I have a Hardi sprayer that I bought earlier this summer, came with some nozzles that my local Hardi dealer does not recognize. He's thinking maybe someone swapped them out for another brand along the way. I need a few replacement nozzles and am hoping that someone here can identify the brand or model of this nozzle to get me back on track. I need a few replacement nozzles and all new caps and tips as the sprayer came without caps or tips.
I also snapped a pic of the sprayer as well as a side shot of the boom which might help you see how the nozzle is mounted. The nozzle has regular 3/8 pipe thread for the cap. Any help would be greatly appreciated.
It really does not matter what the body is as long as you get tips and rings to fit the body. If that fitting you show is pipe thread you can get parts from TeeJet Fertilizer dealer supply will know what you need right from the body if you take it in with you.
Now if you are trying to match a nozzle with new ones I would forget that and get a new set. The wear in the nozzles will give an uneven spray pattern. Thus using more product with the uneven pattern could cost you in the end with a rerun of the sprayer. Stainless will wear the best and the longest. If this is just a deer plot it probably is not a issue for a few acres.
Fertilizer Dealer Supply is in Schoolcraft and Morrice MI based out of Philo IL.
The number for the Morrice store is 517-625-4716 all are knowledgeable people in there.
That tip and the boom are identical to my Hardi, the sprayer looks like an older George White I once had. TeeJet tips and rings fit mine.
Ben
