Farmall M hydraulic capacity
jd6300
New User
I am considering purchasing a wide front Farmall M. It has a 3 pt hitch. I want to run a 3pt Farmland Bale Wrapper. Can I add a Fasse valve or hydraulic multiplier to have 4 remote hoses? Will it have enough capacity to operate my wrapper?
if its a belly pump, it is not a live pump and only has about 800 psi pressure. if a live pump was installed, its about a 12gmp pump and around 1600 or so psi. not sure what your bale wrapper requires, may or may not work.
My thoughts are NO.The 'mag' pump will be marginal.'Belly pump,NO.As important or even more so is reservoir capacity.The M both
reservoirs are 6 to 8 qts.I would want at least 5 gallons.Add a PTO pump and 'remote' reservoir and valves.
(quoted from post at 16:40:54 07/30/15) My thoughts are NO.The 'mag' pump will be marginal.'Belly pump,NO.As important or even more so is reservoir capacity.The M both
Thank you for this info, think I'll pass on the M with it's limited hydraulics for my application.
