Fuel pump ???
Jim in Ma.
Does anyone out there rebuild fuel pumps?
I have a pump off a 4 cul. Mitsubishi engine The number I have is G224 4133 50C. I'm told they are NLA.
Thanks
(quoted from post at 10:57:29 07/25/15) Does anyone out there rebuild fuel pumps?
Thanks
I googled that no. and got a couple of places. check it out.
If you have 12 volts available put on an electric fuel pump, bypass the one that is on there. Wire it to the ignition side of the switch. One like this will do the job.
http://www.amazon.com/Airtex-E8012S-Electric-Fuel-Pump/dp/B000DT7Y7A
Does it have screws holding it together? If so, open it up, see what's wrong. May be something simple and repairable. Otherwise, do some research like Merlynr said, there are probably some NOS out there.
