Allis chalmers wd 45 PTO wont engage
Fish002
New User
I have been using my PTO right along always seem to engage and disengage hard. Now I can't get it to engage at all. I have tightened the linkage and still will not engage. Any ideas?
Probably bent fork inside the housing, from cramming it into gear. It"s just a simple slide assembly inside.
Might be time to drop the gearbox and see what is going on. Drain the oil and remove the pto shaft and 6 (I think) bolts.
AaronSEIA
(reply to post at 20:28:04 07/02/15) bent fork. So I drop the gear box take out gears to get to the fork? Don't own a manual how do you get to the fork. Also if I drop the gear box how much fluid should I expect?
