02 Impala BCM
Mark-Ia
After using "Google" to find out why my message center goes through all the system checks, I have decided the Body Control Module is faulty. Can buy one about anywhere.Is it just a plug and go or does it need to be programed by myself or is a dealer required?
The BCM requires a GM Tech 2 to program and do the theft learn on an '02 Impala. You also cannot use a used one, once a VIN is programmed it is permanent.
