MF 135 Distributor Drive Shaft Replacement.
candhacres
New User
This message is a reply to an archived post by hnolting on May 19, 2014 at 05:40:14.
The original subject was "MF 135 timing problem".
When replacing the distributor drive shaft, do you have to take the front cover off the engine or are you able to replace it from the back side? I have a bad distributor drive shaft I need to replace, and my tractor died in a place that is not very work friendly. And it has a front loader on it that makes matters worse.
Thanks for the help!
