Small "square" bales are variable in size from machine to machine. Volume is length times width times height. i did it in cubic inches with a 14X18X40" small sq. and there were close to 8.7 in a 4X4 round. Jim
40 small bales at 50 lbs would be a ton or 2000 lbs I don't know the average big square I'm guessing 800 lbs so 2 and a half would be a 2000 lbs . That would mean 40 small bales to 2 1/2 big square
Many factor come into play on this. Say if you have square bales that are at say 50lbs and a round bale that is 500lbs well 10 times 50 equals 500. But if you bale like I do an my square bales are in the 35lbs range and my rounds are in the 1800lbs range well a whole lot more squares to a round
dhays
Most accurate thing to do is weigh a few of your rd bales to determine an average for your rd bales then divide the desired sq bale weight into average rd bale weight. A guessed weight is just that merely a guess.
Agree that the tensioning (density as a function of the bailing function, nothing to do with condition of crop) and dimensions of both come into play. I think unless you take both to the scales it's just a crap shoot. But if you can stand 20-30% of error then you can guess......opinion, BTDT
Very hard to be accurate there! Lots of variables on either side of the equation...
What's a typical round bale to YOU? - and what's a typical square bale to YOU?
Around here a 4x4 should usually be between 450 and 600 lbs of hay...
Around here, a small square should be between 35 and 50 lbs...
so - the answer could be anywhere from 9 to 17 small squares in a 4x4 round bale.
on AVERAGE I'd say about 11 - but you will get into trouble if you're trying to calculate a year's feed that way, but to err on the side of excess.
