Changing a 23.1x26 rear tyre.
Can one man manage to change a 23.1x26 rear tyre (Massey Ferguson 97)on his own? Ive been told they are real difficult to change due to the small inside diameter. Any help or suggestions welcome.
I have done it by myself on my old 6600 JD combine and it is better with help.
With that being said, what I did was place the loader bucket close so when I pried the bead off of the rim, I had something to put the tire iron under so I could take the next "bite". (The rim was still bolted to the combine)
When I did the 28L-26 on my 6620, the rim was off of the combine and I used a clevis and a chain via the center hub rim mounting bolt holes to hold the first tire iron for the next bite.
Once the bead was off, I used heavy C clamps, the chain, and the loader to lift the tire up to attack the other bead and remove the tire completely.
It was about all that I wanted though.......
Sorry that I misspelled tyre....LOL
take your pick of profession...
tireman in this instance.
They aren't aliens or robots.
What one man can do, another can do.
Now you just have to decide if you [i:b313f4ee2f]want[/i:b313f4ee2f] to... LOL
Bill I owned a farm tire repair shop for over 20 years--you are right they are 1 of the more difficult size tires to replace. If you are not experienced you may very well be ahead to have a professional switch them. They are far easier to change by yourself if the rim remains on the tractor.
