Billy Schaffer and onan update
JOCCO
Found real bad points so ordered a set, new condencer too This engine has the ignition under the flywheel does not have a coil on top. Grounded one plug wire the other fired per the manual.
That would be the magneto system. Can you post the model and serial number.Check the point push rod. They do wear to one side can cause problems when running. You can file it flat if the angle is not to bad.
