Is it just the picture or is the dark weight bigger than the yellow ones? And there are 2 different John Deere weights but both look the same till you measure or try to put on. One is primary weight for use with only one weight per wheel. The way they are made you cannot stack them, that is where the second style comes in and the center is cut bigger so that it will fit over the center of the primary weight. Those are very scarce and when I was farming with 3 Deere A & B tractors I never was lucky enough to find one of the secondary weights. You can tell by the numbers and the parts book. Usually things can be modified to fit something else.
